4th Balkan Conference on Metallurgy
Scientific achievements and perspective of metals industry in South-East Europe
Zlatibor, Serbia, September 27-29, 2006
With the kind permission  of  Organizing Committee of the 4th Balkan Conference on Metallurgy.
Poster Session - Titles of Papers & Authors:
  1. Recycling of silicon carbide from waste crucibles for smelting and its application in grey iron production
    Markovic
  2. Investigation of influence of temperature and duration of boridization on kinetics of growth the boride layers on pressed samples
    Cirkovic
  3. Pelletization of Waste Metallurgical Powder Using Different Binding Agents with Particular Review on Mechanical Properties of Obtaining Products
    Jovanovic
  4. Analysis of Syntetic Metallurgical Waste Water by Icp-Aes
    Kovacevic
  5. Waste Utilization and Air Enrichment Effects on the Process of Industrial Steel Heating
    Lalovic
  6. Recovery of precious metals from copper concentrate and polymetallic mineral resources
    Marinkovic
  7. Copper Removal from Contaminated Water Using Sinapis Alba L.
    Cosovic
  8. Characterization of wastewater streams from RTB Bor Site, Serbia
    Korac
  9. Pollution prevention and control techniques in the Copper Institute
    Apostolovski-Trujic
  10. Mineralogical characterization of the polymetallic ore concentrate from the Rudnik mine flotation
    Sokic
  11. A study of copper(I) sulphide leaching with sulphuric acid solution containing sodium nitrate
    Sokic
  12. Electromagnetic Stirring in Ladle Furnace
    Venini
  13. New ABB automation for the aluminium hot rolling mill at Impol Seval, Sevojno-Serbia
    Venini
  14. Solvent extraction of palladium from chloride solutions
    Avramovic
  15. Defining of The Available Secondary Energy In The Production Process of Sulphuric Acid the Process of Sulphuric Acid Production
    Ciric
  16. Reduction of tungsten oxide in vertical tube reactor. Matematical model for estimate of time reduction
    Filipovic
  17. The Technological Parameters of Fayalite Concentrate Agglomeration - Sintering and Pelletization
    Grigorova
  18. Thermodynamics of Some Interactions in the System Mn-Fe-Si-V-Ca-O-C
    Marinov
  19. Effect of Po43- to the Morphology of Ag Deposited by Non-Stationary Current Regimes
    Paunovic
  20. Mathematical model for microsegregation of Cu rich Al-Cu15wt.%-Mg Alloys
    Zlaticanin
  21. Quality control of rails
    Sladojevic
  22. High-temperature Cyclic Oxidation of Ti3Al-Based Alloys
    Cvijovic
  23. Characterization of Electromagnetic Casting 2024 Al Alloy Ingots
    Pataric
  24. Application of hydro-isolating and anticorrosive coatings based on secondary sulfur
    Martinovic
  25. Sulfur agglomeration of power-plant ashes and removing of sub-micro ash particles
    Martinovic
  26. Technological aspect processing and dead roasting mechanism of polimetallic sulfide concentrates
    Misic
  27. Gold leaching with thiourea from old bor flotation tailings
    Obradovic
  28. Control of Effective Parameters on Particle Size of Electrolytic Copper Powder by Qualitek Software
    Vatandoost
  29. The evolution characters of a-3 steel in corrsivese enviraonment of vlorabay
    Kasemi
  30. Synthesis and sintering of Cu-Al2O3 nanocomposite powders produced by thermochemical route
    Andic
  31. Industrial investigations of brass scrap recycling in the aim of copper and zinc-oxide production
    Cirkovic
  32. Influence of the termomechanical treatment on dispersion of Pb in brass CuZn39Pb3 products and the ways of chemical determination of Pb after that treatment
    Cvijovic
  33. Thermodynamic analysis of AuIn - Sb system using Oelsen calorimetry
    Gomidzelovic
  34. The analyse of thermal stresses when the elongation is free or hindered
    Karastojkovic
  35. Chemical and Structural Inhomogeneity of The Centrifugally Casted Cr-Mo Steel Tubes
    Katavic
  36. Morphology of electrodeposited silver powder particles
    Maksimovic
  37. Microhardness of Nickel Electrodeposits on Different Substrates
    Radojevic
  38. À Brick-Wall Model for Calculating Young' s Modulus of Particulate Polymer Composites
    Radojevic
  39. Copper matrix hardening by commercial alumina particles
    Rajkovic
  40. Implementation of Image Analysis for Characterization of Refractories and Ceramic Fibres
    Volkov-Husovic
  41. A Thermal shock investigation in alumina based refractory:anisotropy, temperature and stress distribution
    Volkov-Husovic
  42. The Corrosion of Brass and its Inhibition in Acidic Sulphate Solutions
    Avramovic
  43. The influence of gelatine on the corrosion behaviour of cold worked copper wire in alkaline media
    Ivanov
  44. Comparative Thermodynamic Study of SemiconductorGa-Ge-Sb System
    Kostov
  45. The influence of thermo mechanical treatment on recrystallization of AlMg4.5Cu0.5 alloy
    Radovic
  46. The Possibility of Improving the Methodology for Economic-Metallurgic Iron Ores Valuaton
    Gavrilovski
    « « «   Back
