Развитие и индустриално приложение на метода за леене с противоналягане Development and industrial application of the counter pressure casting method Развитие и промышленное применение метода литья с противодавлением акад. Янко Арсов, ст.н.с. I ст. дтн. Емил Момчилов Институт по металознание, БАН, София |
In the last years the requirements to the quality of cast products raise significantly. Through its development and wide industrial application the Counter Pressure Casting Method replied to this challenge. The castings produced by the Counter Pressure Casting Method show improved mechanical, physical and operational properties. The most technical and economical advantages could be obtained in production of heavy-loaded parts of large overall dimensions, parts of complex geometry combining thick and thin walls, parts under high dynamic and especially cyclic walls, parts under high pressure by liquids and gazes, parts under increased temperature etc. Резюме на доклада, представен на пленарната сесия на XI-та Национална конференция "Съвременни леярски технологии", 20 и 21 октомври 2005 г., Ловеч. |
